I'm looking at two different, but similar monitors from ASUS. Both are 24" IPS panels. One is listed as an LED Backlit LCD monitor, and the other as just an LED monitor. I'm not sure if this is just a difference in naming or if there are LED monitors that are not LCD backlit.
The two monitors are
ASUS PA248Q (the one listed as LED only) at $399 Canadian
http://www.newegg.ca/Product/Product.aspx?Item=N82E16824236287&_ga=1.42761125.1236924863.1445791793
And the ASUS VS24AH-P (listed as LED \ LCD) at $289 Canadian
http://www.newegg.ca/Product/Product.aspx?Item=N82E16824236331&_ga=1.42761125.1236924863.1445791793
So if this isn't a naming thing only, I'm wondering how significant the quality difference is between the two that justifies the extra $110 - as both are on a similar sale \ reduction (CAD $).
There are some other differences which probably contribute to the price difference. The more expensive PA248Q goes to 75Hz, and also has display port and a better stand (stand not a consideration for me as I'm VESA mounting) Color quality looks the same in specs. (16.7 Mil & 300 cd/m2)
The cheaper VS24AH-P has a 5ms response as opposed to 6ms on the PA248Q - also not an issue for me as this is for multimedia \ vid editing, not gaming.
Both are VESA mountable which is a must for me.
So I'm wondering is there a significant difference between these two that would justify me paying the extra $110? $400 CAD is about my budget top, and I'm hoping to get a decent-ish IPS (non-gaming) panel for that price.
EDIT: rest of my specs are under my icon to the left here
