T TheMurlocKing Reputable Oct 30, 2015 51 0 4,630 Nov 18, 2015 #1 Anyone know a good brand of led strips to light my case thanks
Solution Dark Lord of Tech Nov 18, 2015 http://www.newegg.com/Product/Product.aspx?Item=N82E16811994051 Something like this?
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,614 1,778 159,590 Nov 18, 2015 #2 http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=100006519%2050072745%2040000255&IsNodeId=1&SubCategory=255&Manufactory=72745&SpeTabStoreType=1 BITFENIX. Upvote 1 Downvote
T TheMurlocKing Reputable Oct 30, 2015 51 0 4,630 Nov 18, 2015 #3 Do you know a good multi color one Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,614 1,778 159,590 Nov 18, 2015 Solution #4 http://www.newegg.com/Product/Product.aspx?Item=N82E16811994051 Something like this? Upvote 0 Downvote Solution
T TheMurlocKing Reputable Oct 30, 2015 51 0 4,630 Nov 18, 2015 #5 Thanks for reply those ones were my original choice, do you think they're good? Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,614 1,778 159,590 Nov 18, 2015 #6 Yes I do. Upvote 1 Downvote
