Good morning,
My knowledge on cars is absolutely terribly but after a small amount of research I fear I may have a head gasket problem.
Car 2001 Renault Clio sport 1.2 petrol 111000 miles.
Symptoms: The radiator cap has a white gooey solution on it. It looks like oil may be mixing in with the radiator water.
I only use this car to go to work and back doing about fifteen miles each way. It never shows as overheating on the temperature gauge. From the research I have found though the symptoms I have generally point towards a head gasket failure.
Does anyone here with good car knowledge have any input on what it could be. The best way to get it resolved. How much I should expect to pay to get it fixed or if it is even worth getting it fixed bare in mind the age of the car.
If you need any more information please ask and i'll tell you what I can.
Thanks Joe.
Thanks Joe.
