M MrRage Reputable Sep 24, 2015 18 0 4,510 Dec 10, 2015 #1 has the title says does anyone recommend a monitor with these specs or slightly different, it is important that it mounts to a monitor bracket as I will be buying 3 of these to mount to one
Solution C C chenw Dec 12, 2015 XB271HU is the best of the 1440p 144hz IPS monitors, failing that the TN's should also support VESA mounting.
C chenw Honorable Oct 25, 2014 1,665 0 12,460 Dec 12, 2015 Solution #2 XB271HU is the best of the 1440p 144hz IPS monitors, failing that the TN's should also support VESA mounting. Upvote 0 Downvote Solution
