Question about older HDMI
digitaldoc Expert Ambassador Oct 31, 2003 5,213 0 36,960 Dec 14, 2015 #2 Did you try a different HDMI cable in case that is the issue? Also make sure the HDMI input is selected on the TV. There is no HDMI to older HDMI adapter.
G gilbert53 Reputable Dec 14, 2015 2 0 4,510 Dec 14, 2015 #3 digitaldoc : Did you try a different HDMI cable in case that is the issue? Also make sure the HDMI input is selected on the TV. There is no HDMI to older HDMI adapter. Thanks. I will try that and advise. I sthere a difference between 2003 HDMI port and the current HDMI from my new cable box?
digitaldoc Expert Ambassador Oct 31, 2003 5,213 0 36,960 Dec 14, 2015 #4 Physically it should fit. http://www.audioholics.com/hdtv-formats/understanding-difference-hdmi-versions Yes, there are different HDMI standards, and a TV set from 2003 is most likely HDMI 1.0.
