IPS and TN has nothing to do with ghosting. The amount of ghosting is not even remotely related to what panel type a monitor is using. It's all about the electronics inside. If they're cutting costs, you're sure to see more ghosting than a higher end monitor.
Even on "1 ms" TN monitors, there's still a massive amount of ghosting, literally the same as a 5 ms monitor, so that dynamic response time spec, don't matter whatsoever. What matters is the pixel persistence, meaning you can achieve 1 ms persistence, if you use Lightboost, for instance. This can be found on most gaming monitors, even IPS. That's because, even if the static response time has changed and gotten a lot faster by moving up in refresh rate, see
1/60 = 16 ms
1/120 = 8 ms
1/144 = 6 ms
It's still not enough to completely get rid of ghosting. An LCD is always on, and thus Lightboost, black frame insertion and ULMB are required, to minimize this effect, there is no other way, other than increasing the refresh rate so much, which in turn would make LCD's obsolete at that point, because nobody would buy such expensive displays.
Regarding the different panel types, and backlight techniques you listed, I just say TN, IPS, VA, OLED, just like k1114, above.
With that said, I strongly suggest buying a VA monitor, it's beyond me why people constantly complain about both IPS and TN, completely missing VA, which has no defects for the most part, even backlight bleed is extremely rare. Majority of VA monitors, you can't even tell if it's on, if it's displaying a black frame. It's pretty straightforward.
When people compare OLED to LCD's, what they do, especially LG, basically the new Apple in my eyes, they are no different, but I digress. What they did just now, a few days ago, was compare their OLED TV to a IPS TV, to prove that the contrast is so much higher.
What they don't dare to do, is compare a high end VA TV, vs an OLED, they won't do that, because then they would lose too many customers. I find that hilarious. To give you an idea, 3000:1 contrast, is enough to hide all black on a monitor with the environment, i.e a dark room while watching a movie, such as the black bars encoded in blu ray source material. The highest end VA right now, has got a contrast of over 5000:1, that's closing in on OLED's shadow detail performance, at less than half the price. The only downside worth mentioining, is are the colors, because OLED are pushing an exclusive HDR format for their TV's, because they think they're Apple, and then we have the viewing angles, that's literally it.
So when shopping for a monitor, it's not exactly black and white, as many people want to believe. What most people do, is put IPS on top, even though VA can display the same accurate colors IPS can. The monitor market is actually moving backwards, they're cutting corners with the high end IPS gaming monitors, it's sad to see, look at over 1k monitors, and compare the edge light uniformity, and then the IPS glow. A $200 TV beats that, that's sad, and I hope we're going to see major improvements soon. They're pushing features, not panel quality, at the moment.
All the best!
