I noticed that when I turned my computer on this morning the resolution was stuck in 1024x768. I thought it would be a simple fix by just increasing the resolution in windows, but it only gave two options.
One was 1024x768, and the other was an even lower resolution. I also noticed that in windows device manager it shows up as a generic non-pnp monitor. The monitor used to show up as an Asus VE248H.
I am also trying to figure out how to update windows 10 as it gets stuck in an automatic repair loop every time I try to install updates. This forces me to reset windows and have to lose all apps I had installed.
Any help on either problem would be appreciated, thank you.
Specs
OS: Windows 10 x64
Display: Asus VE248H
GPU: Gtx 970 Strix
MB: Gigabyte GA-Z77x-UP4 Th
If you need any more information please let me know.
Specs
OS: Windows 10 x64
GPU: Gtx 970 Strix
