Hey everyone, I need some help. I've posted this initially on the Windows 7 forum but I'm re-posting it here as I've just updated to Windows 10 (on the advice of the ASUS helpdesk) but the problem persists. I'm afraid this might be a little long-winded as I don't want to leave out anything that might prove relevant to finding a fix.
My issue
I have a problem with my USB headset. The sound works perfectly when watching a movie / youtube / playing simple games; however as soon as I launch a program that wants to use the microphone, the audio from the headset cuts out and I need to uninstall and reinstall the headset drivers to get the sound working. If I leave open the application that uses the mic, the sound stays off regardless of what I do.
This consistently happens with programs such as Skype, games that use voice comms (e.g. CS:GO) and even the 'configure your mic' app in Windows. Even if I set another device as the default mic, the sound still cuts out when the relevant program is launched. It has only been happening since I got my new motherboard; before on a Gigabyte MB I had no problems whatsoever.
MB: ASUS B150 Pro Gaming D3 ( https://www.asus.com/Motherboards/B150-PRO-GAMING-D3/ )
OS: Windows 10 Home (version 1511 build 10586.36)
Headset: Generic USB headset ( http://www.tcstar.com.tw/tcstar/ch/htm/products/micear/tce6860.htm )
Things I have tried to fix the problem
Other information that may or may not be relevant
That's everything I can think of for now, many thanks in advance for any help I can get!
My issue
■Reformatted my HD - not my first option, but didn't work.
■Reinstalled the soundcard drivers - I know a USB mic doesn't use the normal soundcard, but it was worth a try. I've tried versions R2.79, 6.0.1.6418 and 6.0.1.6305 (Realtek), all with the same non-result.
■Tested with a non-USB headset - could not replicate the error
■Disabled all other audio devices in Device Manager as suggested in this thread - http://www.tomshardware.com/answers/id-1976501/audio-usb-headset-windows.html - didn't work.
■Tested the USB headset on another PC - worked fine.
■Tested with a brand new identical headset - no change
■Tried other USB ports on the PC - no change
■Set another mic as default in the Playback Devices tab of the Sound window, no change.
■Upgrade from Windows 7 to Windows 10 - no change
■Beat my head against a brick wall Temporary decrease in visual resolution and a slight ringing noise, but no discernible change to the computer issue.
■In Device Manager, the headset is identified as "2.4G Wireless Headset"
■Once the sound cuts out, the microphone continues to work.
■When the computer cuts the sound to the headset, other output devices remain unaffected.
■Vending machines kill more people than sharks every year.
