PC was working hard and without a single issue for about 1.5 month. I overclock CPU only. In 100% load it shows 90 Celsius per core max and 81 per core stable with Kraken x61 cooling system on it.
Suddenly whea_uncorrectable_error starts to appear on RealBench Stress Test and on typical video encoding work.
Windows updates were installed. New Nvidia drivers were installed. NZXT Cam update were installed. New LAN switch were installed in office. Thats all.
I've tried to Update BIOS and reinstall Windows on Clean. I've tried to Recover Acronis' Windows copy which worked stable from the day 1.
It seems there is no WHEA error on not overclocked CPU but I didn't tried it for long. In 4.5GHz RealBench shows Error in about 14 minutes. On 3.0GHz it holds up one 15 min round.
AIDA64 don't show me WHEA error at all (about 20 mins tested).
Also some strange USB behaviour appears. Connections not working properly every time. Not sure it linked somehow.
I raised up Core Voltage from 1.3 to 1.35 without a result. Raised up again to 1.4. Temp also rised to 102 Celsius per core max but it looks like system became stable again at least for 30 minutes RealBench test.
Spend 3 days trying to understand what's going on. Hope you can help.
All PC info in Speccy:
http://speccy.piriform.com/results/TiXiOvOQMBToQiXul60vLWi
Dump file:
https://yadi.sk/d/hEDogEZgn9i8w
Dump file:
