I recently purchased a Corsair H60 water cooler for my i7 4770k, I've noticed that my idle temps sit around 40C, but just last night when it was rather warm and I had just finished playing GTA V for 2 hours my temps weren't going below 60c at idle. My temps while running Intel Burn Test sit at around 80C.
- I have reapplied Arctic Silver Thermal paste 3 times now, nothing.
- I have reseated the cooling block several times, making sure the thermal paste was applied properly of course.
- I've used different fan connectors for the H60 fan and the cooler itself. The best temps (40 - 50 idle, 70 while playing games, and 80 - 100 while running burn test) was when I plugged the cooling block into the PSU using adapters.
- I've tried tightening and loosening the water block.
- I'm not running any overclock whatsoever, just a stock i7 4770K.
- My case has rather poor airflow, although, my cpu almost immediately goes to 80C plus when I start the burn test so I don't think that the airflow is the problem.
- While playing games I get around 60C, so I'm not really damaging anything, but the thing is, I render videos using Sony Vegas and that is almost as taxing as burn test and it can sometimes run for several hours.
Any help is much appreciated, thanks.
