M mccfrank Reputable Feb 7, 2016 3 0 4,510 Feb 7, 2016 #1 My Samsung 20 inch lcd power supply (internal) died and rather than replace the dead capacitors I was thinking of using one of the new external power supplies to resurrect the monitor. Is this even possible?
Solution V V Vasim92 Feb 7, 2016 you have to check the output voltage and ampere of that power supply which you gonna input in you monitor...
V Vasim92 Reputable Feb 7, 2016 89 0 4,660 Feb 7, 2016 Solution #2 you have to check the output voltage and ampere of that power supply which you gonna input in you monitor... Upvote 0 Downvote Solution
M mccfrank Reputable Feb 7, 2016 3 0 4,510 Feb 7, 2016 #3 Vasim92 : you have to check the output voltage and ampere of that power supply which you gonna input in you monitor... Upvote 0 Downvote
M mccfrank Reputable Feb 7, 2016 3 0 4,510 Feb 7, 2016 #4 Yes I realized that already. Just wondering if it's a practical solution and whether anyone had done it. Upvote 0 Downvote
V Vasim92 Reputable Feb 7, 2016 89 0 4,660 Feb 7, 2016 #5 it can be . don't worry . if its according to input and out put. Upvote 0 Downvote
