After around 5-10 mins of playing audio from a game or a video, audio will completely stop. The only way to fix this that I've found is either restart or unplug and repluging my headphones. Playing audio through the monitor yields the same issue so its unlikely my headphones are the problem.
Running on Windows 10
Using Razer Kraken 7.1 Chroma headphones
Tried doing a virus check with no result.
Tried a total disconnect from power.
Just about to try uninstalling my sound drivers and having windows update them.
If you have any questions, feel free to ask! If you have any suggestions then feel free to share!
