Hello everyone, i have a problem with my Computer.
Basically days ago i bought a DJ Console from a friend, that console had a CD with Drivers to install on my PC (Obv), so i installed them with Virtual Dj and yeah it worked for some days, then i installed Virtual DJ 8 (the version from the disk was the 7th) and after unistalling it i've got a problem in the 7th and i reinstalled it, but when unistalling it i've selected ''Custom Unistall'' and i deleted all the things that were created from that installer.
Then after trying to reinstall it a problem appeared... it was ''you don't have enough space on E:''
But the problem is that i don't even have a E: hard disk, my main hard disk is C:\ , i went into the settings and i tried to change the default location where files will be saved and it didn't worked.
this morning (it's morning in my country now hahhha) i've installed Windows 10 (i had windows 7) it went all fine and i did it with the installation of virtual dj but that problem in some not important actions i do like downloading or upgrading a program still appear and i think the registry has something to do with it.
Someone please help me and sorry for my bad english.
Thanks
Thanks
