Ok So I have two problems. First one.
Weird Blur/Darken on objects
I own a Acer GN246HL. Its a 144hz monitor. When ever I move side to side in a game the objects blur and have like a RGB Trailpath behind them and edges Darken. This is on Multiple games tested. And I have 3 monitors and it does the same on all 3 so its not a monitor problem.
Second Problem:
Setting up 3 Monitors for 144hz
I own two MSI GTX 980ti's in SLI.
I have one Acer monitor connected via DVI-D running fine at 144hz. Fine!
I have one Acer monitor connected via DVI-D to a Active Adapter then out to a display port on my GPU.
Yes through the Nvidia control panel I am able to run the monitor at 144hz with the adapter although I run into two problems, firstly I have a annoying popup from the monitor's software saying "Incorrect cable Please use the Dual link DVI cable that came with your monitor" when infact I am.
Also! the screen becomes full of Fake Dead pixels, (These pixels arent really dead they just look like they are)
When switching the monitor back to 60hz through the Nvidia control panel, this pop up goes away, and so do the fake dead pixels.
If anymore info is needed let me know.
Here is the link to the adapater
http://www.amazon.com/VisionTek-DisplayPort-DVI-D-Active-Adapter/dp/B00DYRQXMK?ie=UTF8&psc=1&redirect=true&ref_=oh_aui_detailpage_o01_s00
Second Problem:
