Well I've always surfed this forum in seek of help when I had a problem (wasn't a register user by that time) and it always helped me in any way either to solve my problem or to keep my in the way for a solution, now is my turn I guess to ask the problem here because I don't really know what to do!
Here is the thing, yesterday I set-up two same LG monitors (both 1080p) they're new, same thing for my computer (well it has a few months now..) the problem is the PRIMARY display is connected to the DVI-VGA port of the back of the CPU directly into the graphics card (R7 360 2GB GDDR5) and the other display is connected on the DisplayPort (with a VGA-DisplayPort adapter) both works perfectly fine EXCEPT for one little thing
One display (the one connected to DVI-VGA is @ 1920x1080p 60hz) the other display (the one connected to the DisplayPort is @ 1024x768 75hz) and when I try to select a higher resolution for the secondary display for example 1280x720 or even the recommended one (1920x1080p) it goes black and says Power Save mode and the red power light flickers on and off, if I get back the resolution to 1024x768 it works fine..
Hope I explained myself correct!
Thanks!
Thanks!
