Hello there!
Last year I built a PC, played around with it for a while but then, due to real life, didn't have the chance to use it often. Now I recently started using it again, but I soon noticed a very annoying issue; my display has incredibly low volume. Back when I still used my pc, I mostly used headphones, but due to my work I cannot use them so I prefer to have the display speakers on.
All sound settings are maxed, loudness equation has been enabled in the properties and the device is set as default. I have a hdmi cable so cables shouldn't be an issue at all.
My drivers are up to date as it uses the nvidia HD audio.
I know the sound can go higher, because whenever I test the device in playback devices it gives an incredibly loud noise which is also seen on the sound bar thing to the right.
But whenever I play sound from other programs while keeping an eye on that sound bar, it never seems to go over 2-3 of the bars. Which I know isn't right.
Running out of options here, so wondering if I can get some help here as it is seriously annoying me when I want to watch a film across the room! Even my phone has higher volume!
Thank you for reading
