Little history: So I used to plug in my headphones with an integrated mic into the pink and green ports on the front of my computer, and it worked perfectly. I could use the mic and headphones.
Then something happened. Now when I plug them in, I get a notification from realtek HD audio manager that I have plugged an audio device in, but when I open said manager, it says, "you are seeing a blank page because there is no audio devices in the system". This is the exact same application that just told me I plugged something in! I don't know what to do. Can I reinstall the Realtek HD audio manager? I doesn't show up in control panel as an application to uninstall.
Here's another peculiar thing: Under device manager in control panel all my audio devices show up. But if I right click on the sound icon in the taskbar in the bottom right hand corner and open playback or recording devices, it says, "no audio devices are installed". It clearly shows them all in device manager! I have tried installing all different drivers - ones from the manufacturer website, and let windows install the default ones. I have a hard time believing this is a driver related issue.
I actually even bought a cheap plug in play USB mic that people say works with just the windows default driver. ( http://smile.amazon.com/Adjustable-Microphone-Compatible-Chatting-Recording/dp/B00UZY2YQE?ie=UTF8&psc=1&redirect=true&ref_=oh_aui_detailpage_o00_s00 ) I plug it in, the driver is installed, and it shows up under device manager. But I cannot select it as a recording device. I also HIGHLY doubt this is a driver issue.
One last thing I tried; I was having an issue in Adobe Premiere where I didn't have any sound at all. I fixed this by installing asio4all. I thought maybe this was the issue, so I uninstalled it but the issues still persist.
Either way, I would consider myself relatively tech-savvy and I am clueless. I have tried everything I can think of.
