Your pc ran into a problem!?!?!?!
Somthingsick909
29
So recently when I try to boot up my pc i get this error message. "Your PC ran into a problem and needs to restart. We're just collecting some error info. and then we'll restart for you(0% Complete)." The pc boots up and instead of going to my desktop gives me that and i cant even get to my desktop does anyone know why? using windows 10.
Another option would be to start pressing F8 or Shift + F8 as soon as the computer turns on.
If that doesn't work, if you have the Windows 10 DVD, you can insert that into the computer. When the computer turns on, it should boot and load the dvd giving you some options.
GamingInsider
118
