First time computer builder here. Please read though my post and leave any helpful advice for me, thanks!
Approximate Purchase Date: This week hopefully!
Budget Range: Under $1500 - $2,000 after rebates, but if it doesn't have to be that high then I'm ok where I'm currently at, but I do have room to go higher.
System Usage from Most to Least Important: Gaming, Photo Editing/Light Photoshop, basic web browsing/watching movies
Are you buying a monitor: Yes
Parts to Upgrade: Need everything
Do you need to buy OS: Yes (Windows 10)
Preferred Website(s) for Parts: newegg.com
Parts Preferences: Intel Processor
Overclocking: Maybe, probably not though
SLI or Crossfire: No
Your Monitor Resolution: 1920x1080
And Most Importantly, Why Are You Upgrading: I've always wanted to build my own computer and make it primarily a powerhouse for gaming. I can go up in price from where my wish list is currently at below here. An example may be adding in a SSD and if that's something I really need/is recommended. I also want to make sure my build is something that will last and can be easily upgraded in the future as well and that all the parts fit well with one another. I'm starting from scratch as well so I needed EVERYTHING. Are there any parts I'm missing at this time.
Thanks a bunch!
http://secure.newegg.com/WishList/PublicWishDetail.aspx?WishListNumber=26906371
Thanks a bunch!
