it depends on the kind of monitor you are using , some times there's a chance to save it by just disconnecting it immediately and let it dry for few days. but if you can see that the water has reached behind the panel and combined with crystal or turned off some LEDs , i don't think you could fix it. and i don't know if the warranty supports that kind of damage but if they do send it to them.
