2 days ago, my samsung monitor just completely stopped working. After I turned it off to go for a shower the usual blue power indicator which should be burning stopped burning. I checked the power cable to see if maybe it moved out of its socket, which it didn't. After a bit of twisting and turning of the plug within the socket, I noticed that from certain angles the blue power indicator would flash on for a split second. That's all it does.
Not sure if it's a monitor or power cable related issue, I don't have a secondary monitor to use this power cable on.
Any help is appreciated.
