V VladEusebiu Honorable Oct 31, 2014 109 3 10,685 Jul 18, 2016 #1 What is intel r management engine interface? , can someone tell me if i need this driver or not ? And what it does?
Solution basroil Jul 18, 2016 If you use RAID or things like SSD cache, you should have that. It doesn't hurt to install it just in case, doesn't run unless you need it.
basroil Glorious Oct 19, 2013 8,698 1 46,960 Jul 18, 2016 Solution #2 If you use RAID or things like SSD cache, you should have that. It doesn't hurt to install it just in case, doesn't run unless you need it. Upvote 0 Downvote Solution
