so i just built a new pc
specs: intel core i7 6700k
cooler: Cooler Master Hyper 212 EVO
motherboard: gigabyte h170 gaming 3
Storage: 1tb seagate 7200rpm hdd, 120gb kingston ssd
graphics: integrated graphics
ram: 16gb crucial ballistic sport ddr4
psu: FSP Group 600W ATX Single Rail Power Supply
headphones: apple earphones via 3.5mm, turtlebeach p11 via usb
and i use my turtle beach ones as my main headset and it plugs in with usb. After about 2 months of using the new pc my mic on my 4 year old headset broke so i decided to use a spare i had lying around. This spare one plugs in via 3.5mm jack on both headphone and microphone jack. When i plugged in the headset, the audio worked normally but the mic would not work. Since i used a usb headset i never noticed this problem before. Now i couldnt figure out what was wrong so i thought it was a driver issue so i tried reinstalling the realtek audio driver but i just ended up making things worse and now i cant even get sound anymore. If i use usb then i do get sound but if i use the 3.5mm jack i get the little mute symbol on the bottom right. All my drivers are up to date and I have already checked services and windows audio and audio endpoint builder are both running and are on automatic. Troubleshooting says the following:
Back Pannel:
under the detailed tab it says issues found:
Audio services not reponding not fixed
restart audio devices completed
the speaker, headset, or headphone is unplugged not fixed
plug in speaker headset or headphone informational
potential issues that were checked
One or more audio service isnt running issue not present
Audio device is disabled issue not present
under device state it says
state: unplugged
status code: 8
help link: http://msdn.microsoft.com/en-us/library/aa363230(VS.85).aspx
my headphone IS plugged in and the audio manager recognizes it but it says unplugged
also i have no idea what anything on that webpage means
On the front panel:
audio services not responding not fixed
restart audio device completed
Audio device is disabled not fixed
the audio device you currently selected is turned off in windows
enable this audio device completed
enable the selected audio device to play or receive sound
one or more audio service isnt running issue not present
any and all help is appreciated
Thanks
Back Pannel:
state: unplugged
status code: 8
On the front panel:
Thanks
