I'm looking for an explanation, and theory that how a 4 pin PWM Y splitter would work with
different
type of fans with different pin layouts in a 4pin connector on the motherboard.
The splitter has two end one with 4 pin and another with 3pin. I know that one of them is only 3 pin, because the splitter need to know only one fan speed , and controll both fan based on that.
But, how you controll a 4 pin and a 3 pin fan?
Because the 4 pin connects perfectly (gets 4pin from splitter),
but the 3 pin fan only gets 2 pin from the other head of the splitter.
Will the 2 fan stay on the same level of rpm, or differ in some level?
Does two different brand cause conflict?
I also interested in two 3pin fan with a 4pin splitter.
Please do not answer if it works or not, rather how will it work.
I am not an expert in thic topic, but rather curios about how fans will behave.
different
