PLEASE READ!!! It's been a year and a half, really need help..
Hi, here's my problem.
Specs of car are
2000 Mazda 626, LX V6
Now, about a year & a half ago my father went to start the car, he was going to take it to the shop & get a new battery & see why the car kept swelling the battery up & making it so hot. So he takes the battery cables off (so he could get to the mechanic without the battery swelling up/exploding) which he's done countless times in the past, but this time when he did it, the headlights flashed, windshield wipers came on & the car Reved down until it was off. From then on it hasn't been able to start.
Windshield wipers do not work
Turn signals do not work
Car will crank but not start
Fuel pump does not engage, when you out the key in, the car beeps & nothing on the dash lights up (except for door open indicator), and when you turn the key to the ON position, nothing else happens it just sits there beeping fast instead of going to the 6 beep sequence then stopping.. Fuel pump doesn't engage. Wipers don't work nor do turn signals. The car will crank but not turn over. Now, it was up until this point that me and him thought it was okay to disconnect the battery while the car was running as the alternator would take over.. After this happened I did some research and learned that the battery acts as a capacitor and limits voltage spikes. So, yeah, it was a dumb move. Any idea on what the hell happened!? Literally I've searched the Internet hundreds of times with different wording & no one else in the entire planet has ever had this happen!? I can't find ONE other person with this problem. It's like everyone is clueless. &I no we haven't taken it to the mechanic as it costs money to tow it there and be looked at.. Haven't tried a new battery, but we have tried jumping it with another car which acts as a new battery (as the engine cranks & the indoor lights are bright) so we definitely know it's not the battery.
So rundown
-tried disconnecting battery cables while car was running
-car shut off
-won't start now
-dash doesn't work, can't see mileage or anything else (fuel gauge etc)
-cranks, doesn't start
- fuel pump makes no noise
- beeping sequence stays same when key is inserted into the ignition
Please help!
Specs of car are
So rundown
-car shut off
-won't start now
Please help!
