This is a bit of unique situation, but I am working on an unmanned boat to which I'd like to connect to via wifi (because of some IP based equipment on board, currently generates it's own wifi AP but has maybe 20ft range).
I know other drone manufacturers have been able to use Wifi for their aircraft, such as the DJI Phantom and 3DR solo and get some decent range - however I am not sure what type of hardware they're using to do it.
Here it what I'm going to try:
If this range needs to be improved, perhaps I can add some amplifiers to both the routers.
Since this is a mobile vehicle, directional links won't work. The data throughput doesn't have to be that great, no 4k video or anything like that - but I'd like to get >2500ft LOS. Certainly DJI has achieved high def video over greater differences.
I currently use seperate links for everything. Video is potato cam-def 5.8ghz, telemetry and navigational control is 900mhz, and R/C manual control is 2.4ghz. None of these have that great of range, not more than 1500ft. So, if I can make this method work at match or exceed that range, it'd be awesome.
What are your thoughts? Any suggestions are appreciated!
Adding a Wifi router to the boat with 9dbi antennas. The onboard low powered wifi device (via AP mode) and an ethernet based IP camera will connect to this.
Another router with 9dbi antennas at my base station, configured as a repeater to rebroadcast this signal
My tablet/computer etc connected to the 2nd router.
