This is one other thought. Power. On my older computers, I can hear the fan speed change slightly when I plug/unplug the usb devices. It was because, although small, there was a drain on the power supply from the computer to power whatever item I plugged into the usb port. Every device is different. an example is a camera vs a simple memory stick. Give it a try on your pc. It may be a similar situation. good luck.
