Hi
Just purchased a Lian-Li PC-9f case, but do not see in the manual where it says that the top fan (140) is intake or outtake. Side fans are all installed, but I purchased a fan for the top of the case as it did not come with one, and would like to install it in the right direction. It's Fri, and probably wont get an answer for another couple of days if I email them, so I was hoping that someone her might know.
Thanks!
Thanks!
