Only One Side Of Monitor Getting Cut Off (VGA)
insanekiller1
21
I have a problem, I started using VGA for my setup so I can switch my monitor back and fourth from HDMI (PlayStation 4) and VGA (Desktop). The right side of my screen is being cut off by about 1-2 inches. I also have gray lines vertical when I switched to VGA (probably nothing to do with this).
I have a double monitor setup, when I unplug the 2nd monitor (This monitor is not the problem) it doesn't change anything.
Images
http://imgur.com/a/Um2FW
I tried out this guide already: http://www.tomsguide.com/forum/id-2643663/problem-monitor-screen-cut-edges.html
It didn't work, because only one side if cut off, whilst both edges were moving when trying to resize.
Note: Both monitors are setup with VGA
Specs:
Monitors:
ViewSonic VA2465 SERIES (Problem) (Plug n Play)
Dell E1914H (No Problem) (Plug n Play)
CPU:
AMD FX-6300
GPU:
EVGA GeForce GTX 750Ti FTW (Updated to Latest Drivers)
Motherboard:
Gigabyte 970A-DS3P (Updated BIOS)
insanekiller1
21
Didn't even think about doing that, this fixed my screen and the weird stripes on the screen.
Thanks
