tarmiricmi Personally I wouldn't go any higher than a 750 Ti. In my humble opinion, you're fortunate that your 240 watt PSU can run even that. Your i5-3550 alone has a 77 watt TDP. In addition it has to power the motherboard, RAM, HDD, fans, etc. Not to mention that the vast majority of these pre-builts come with cheap quality power supplies that could never sustain DC current at their max rated wattage. Since your PSU is 240 watts, then I presume that you have the SSF (Small Form Factor) version of the Thinkcentre M92p (
http://shop.lenovo.com/us/en/desktops/thinkcentre/m-series-towers/m92p/#tab-tech_specs )
Tower: 92% 450W Single Output PSU
Tower: 85% 280W Single Output PSU
SFF: 92% 240W Single Output PSU
SFF: 85% 240W Single Output PSU
Your best options are:
(1) Install a GTX 750 Ti / keep current power supply. When you "tried" the 750 Ti, was it in this specific computer? I'd be surprised if anything but a single slot variant physically fit inside this computer, according to the PCIe x16 specs I see:
MSI GTX 750 Ti (model # N750 Ti-2GD5TLP)
$119.99 ($109.99 after $10.00 rebate card)
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127836&ignorebbr=1&cm_re=750_ti-_-14-127-836-_-Product
* I'm not 100% sure even this card will fit in your computer because it's technically 1.5 slots wide, due to the air cooler. If you decide to purchase, you should make sure to buy it from a website with a no-hassle return policy (e.g. Amazon, NewEgg, etc).
"1 low profile PCI Express x16 (164 pins/8GB per direction or 16GB duplex/12v) (SFF)"
(2) Replace the power supply and buy a more powerful graphics card. ! I have serious doubt that this is even possible. I did a search for a OEM power supply on Ebay and located model Liteon 54Y8849. From the picture it does not appear to be standard ATX dimensions, but I could be mistaken. If it's possible to upgrade the power supply then I would buy a Seasonic S12II 520 and purchase a dual slot GTX 1060. This would require that the case be modded. I've never done such a mod on this case, and this is definitely not a path that I would go down.
