I realise that this topic may be more appropriately discussed somewhere on the Adobe forums (I have also posted there), but since the blue screen error message has to do with my SSD I thought it should go on Tom's Hardware.
Basically when I start using Adobe Premiere Pro CC (latest version up to date) It'll be OK for a while (a few seconds or minutes) then the SSD crashes into a blue screen which says: Your PC ran into a problem and needs to restart. Then it displays a percentage and and a face. It then restarts no problem.
I have been using the program with an OC'd i5 4690K @ 4.0GHz with adequate liquid cooling for ages, and 16GB DDR3 RAM @ 1866MHz. Perhaps the CPU is overheating, although I'm not sure if that explains an SSD crash. Besides, OCCT shows that the CPU is stable up to 4.0GHz, and my temps are usually around 32 degrees per core.
Thanks for the help
Thanks for the help
