Im currently running a Asus VG248QE Monitor With the EVGA GTW 1080 FTW and planning to buy another one for a dual monitor display.
I am confused by the fact that the GPU has one Dual Link DVI port and the rest are HDMI 2.0b or DisplayPorts 1.4. My monitor now is connected to the Dual Link DVI so i can get 144Hz running on it. So will my second monitor be restricted to 60Hz? or can i get it to be 144Hz.
If so what cable do i need to buy for it to work with 144Hz?
Monitor: https://www.amazon.co.uk/Asus-VG248QE-24-inch-LED-Monitor/dp/B00B19T7QC/ref=sr_1_1?ie=UTF8&qid=1475257297&sr=8-1&keywords=asus+vg248qe
GPU: https://www.scan.co.uk/products/evga-geforce-gtx-1080-ftw-gaming-acx-30-8gb-gddr5x-vr-ready-graphics-card-2560-core-1721mhz-gpu-1860
Thank you for any help.
