Does the motherboard control the speed of a water pump
matthew4mckeever
145
Going to be sorting out/fixing a friends pc. Just need to know one thing nothing else.
Has a h55 cooler, if the fan for the cooler is connected to the cpu_fan header I understand that will be pwm controlled.
There isint a cpu_opt header on the mobo however.
As some motherboards have the ability to contrl the speed of 3 pin fans as well as 4 pin fans, if his does. Will connecting the water pump to a fan header chang ethe speed of the water pump motor? The wire on the water pump is 2 pin i believe.
