So I have just recently built a new computer and it works great except that my monitor is hazy (main monitor), my 2nd monitor isnt too hazy but I think its hazy just from being a bit old, anyways my main monitor is plugged into my GTX 1080 zotac amp extreme with Display port (I have also tried DVI, still hazy) and my 2nd monitor is plugged into my onboard graphics, I tried to see if the issue is because my monitor is defective by taking my main monitor display and taking it out of the 1080 and plugging it in the onboard graphics, it seemed that the display was no longer blurry and seemed fine, so I assumed it was either my PSU or Graphics card and their may be a low chance it may be the PCI slot. What should I do? I'm desperate to get a solution and no one in the computer shops I went to know what to do? Is my PCI Cable defective and should I try to switch it? Is my pci slot defective or is my GPU defective? Keep in mind not everything is hazy/blurry, some text appears fine and is readable and some other text is almost completely pixelated, games also apear sort of pixelated such as GTA V when I look at the city I can see the blurry building, i have started multiple forums but have gotten no responses, please help it will be greatly appreciated and I'm sad that my new computer is experincing this problem.
