As the title says, i reached stable 4.5 ghz oc a few months back, but because of the power supply i reverted it back. It was enough to know that i can do it. But the situation has changed and i got some excess money in my pocket so i want to buy a few parts to oc over 4.5 ghz. So the idea is to change my psu first and then look at the water cooling options for cpu cooling. I would also need some way of cooling the mbu. So can you guys help with suggestions?
0. would my components even managed or survive ocing over 4.5 ghz?
1. what psu do you suggest, im looking long range, so 1000 w+, money is not the issue now?
2. water cooling, which one, yes no, should i stick with 4.5 ghz with hyper 212 evo and get maybe 2x r9 390s and oc them?
3. if i take water cooling, what to take for mbo cooling?
any advice or suggestion is welcomed, thanks in advance guys^^
p.s. forgot the parts:
cpu - fx 8350 (125 w)
gpu - sapphire r9 390 nitro
mbo - gigabyte 990 fxa ud3
cooler - hyper 212 evo
psu - corsair cx 750
ram - forgot got 16 ghz of something
