I just ordered a second monitor it's going to be my main monitor and it's capable of 144hz. But it says in the monitor description that it only can be 144hz while on DisplayPort. But my capture card I hdmi in and out. I also have another monitor 60hz 1920x 1080 and I use hdmi for it. My gpu has only one hdmi output. How do I make this so it can stream the main monitor to the capture card?
I was finding a solution and thought that I could use an extended screen on windows settings for the physical monitors and then a duplicate of the main screen to elgato for the one output from the gpu I can connect a dvi to hdmi converter or connect vga through the mother board I think.
Thanks
Thanks
