I recently built a pretty decent gaming PC which I wanted to run as silently as possible. My previous PC was water cooled and I found the pump and subsequent radiator fans a little distracting. In the new build I opted for a BeQuiet! Dark Rock Pro3 and it is very quiet.
I wanted to get some extra performance from the CPU (i7 6700K) so I overclocked it. However i've noticed the CPU fan is pretty much full throttle during any gaming I do and i'm not sure if overclocking with an air cooled unit is good for my CPU. So first question - Is over clocking with an air cooler wise?
In relation to water cooling, i'm hugely tempted to get a decent unit to help my CPU, but I don't want to compromise the silent running and overclock. If anybody has any suggestions as to what cooler to use it would be very much appreciated. My previous water cooler was a Corsair and the pump and fans were pretty loud, I was thinking I could get a similar unit and replace the fans with quieter ones perhaps? Any suggestions / help would be welcome.
Thanks
Thanks
