Hard to say without putting eyes or hands on it. Did you replace the intake manifold gasket (upper & lower) when doing the work on the rings and pistons? Those are pretty notorious for leaking on the 3.1, especially the lower intake gasket. Also did you have the head checked when you pulled it off? The aluminum heads are known for warping and may need to be milled flat again and/or checked for cracks (hairline).
