Specs
OS: Windows 10
Mobo: MSI Z97 PC Mate
CPU: Intel i-5 4460k
GPU: MSI GTX 970 LIMITED
RAM: Corsair Vengeance Pro 16gb (8x2) DDR3-1866
PSU: Corsair CX 600W 80+ Bronze Semi-Modular ATX
I also have a wifi network card installed.
I would like to keep in mind that I do not expect to find a solution, but am instead simply just looking for some extra possible insight into my problem.
Hello! So ever since I first built my computer (around 1.5 years ago), I have had this strange... uh... bug(?) with it. Anytime I start it up, System Interrupts steals about 14% of my cpu. The problem is resolved when I restart my computer. (note: specifically pressing the Windows restart button in the start menu. I have a restart button on my comp but I have never pressed it so I have no idea whether or not it resolves the issue)
After a quick google search, all I have really found is that System Interrupts is caused by something not working properly.
Over the past 1.5 years, this is the small amount of knowledge about it I have built up:
Additionally, I have generally never had problems with my computer. No random shut-offs or black screens. Launches perfectly every time (other than sys interrupts ofc). My comp is almost never on for more than 1 day. I don't believe it has ever overheated, although I do push the cpu close sometimes. Then again, the issue has existed ever since I made the comp, so I doubt that would be a cause.
So! By process of elimination, this has led me to believe it is either
What I would like is some insight as to what could be causing this problem. What part of my comp do you think could be the culprit, or is it more likely a combination of them not working properly together?
Thank you for your time.
OS: Windows 10
The only surefire trigger (other than starting up my computer) I have found for System Interrupts is when I put my computer to sleep.
It has nothing to do with my peripherals, as switching them around with others does not affect the issue in any way.
I am fairly confident that all of my drivers are the correct ones and are installed properly.
Over the course of its lifetime, I have reset this comp twice to keep things nice and clean. Both times I have used the Windows 10 "Reset this PC" option, and I have used both options it comes with. This leads me to believe it is not a problem with the OS unless the OS is clashing with one of my parts.
Some random minor fault in one of my parts
Some random conflict that is happening between two (or more I guess) of my parts.
The OS is clashing with one of my parts
