Hello folks,
I'm using the EZM Deluxe Triple Monitor Mount Stand and have two Asus PG278Q monitors (TN) and one Asus PG279Q (IPS) mounted on it.
I found this week when I set everything up that when I go to wrench or make some other adjustment with a tool on the metal parts behind the two side monitors, it will occasionally cause one or both of them to lose signal until I stop touching the metal part to it.
Any idea what I need to do to eliminate what seems to be some sort of grounding issue? I am working on cable management and just ordered longer cables as right now some of them hug the monitors a bit, not sure if that's able to play any role into it. I also have two small logitech speakers that sit below the monitors, wonder if they could be introducing anything?
I just want to say thank you very much for the help in advance. Hope everyone had a good Thanksgiving
