Hi!
I bought a new cooler for my AMD FX 6350. I never changed a cooler before, so when i tried dismantle the old fan, the cpu is remained on it. It just came out from the slot. It stucked on the fan and i had very difficult times to get it off. I didn't saw any damage in on the socket or on the mobo, so i installed the new fan, and done. Everything is working, exept the fact that my system is crashing random since then. It's crashing when i play (this is rare, but it happened a few times), it crashes when i watch movies, or browsing the net, or if i do nothing on it it still crash. Nothing is working and i need to reset it. No sound, no mouse, just the frozen screen. And the reset button isn't working. The button itself is fine, but when i press it, the system isn't reseting, just black screen and nothing. I need to press and hold the start button.
My question is, that my MoBo or my CPU is dying? Or maybe anything else? Because i don't know. I never had this problem before. I tried many test programs on the MoBo, GPU, CPU, RAM, PSU, and no luck, everything is fine. No overheating, no problems so far, and i cleaned the whole chassis.
Win 10 up to date, GPU up to date, MoBo up to date. I think the problem is hardware problem not software.
If anyone has any suggestion, i'm here to read it.
Thank You!
Thank You!
