Asus VG248QE UK Power Cable
John_17
49
So I recently bought the monitor mentioned in the title (Asus VG248QE), however since I was going to another country I decided to buy it other there, and at the time I didn't think it would come with that countries power cord (Poland), so I would rather avoid using an adapter for long term and would just prefer to use power cord with UK plug.
The question is, where can I buy one that will be right for my monitor? I'm not sure if they're any different from one another, so I would rather ask here. I would prefer if the power cord was available for purchase on Amazon.
Does the end that plugs into the monitor look like the lead that plugs into your kettle? If so then you want an I.E.C to UK 3pin plug mains lead.
John_17
49
Just buy the cheapest (which is why I linked a £2 one from eBay)
You're running a 60w monitor off it not a 1000w PSU so as long as its British kite stamped its fine
These will all come with 13a fuses fitted in the plug , swap for a 3a before you even use it.
