Hey! I just finished building my first PC, and when I turn it on, everything is running and on, all the fans in my case and on my components are going, but when I connect a monitor to it, the screen shows a "No Signal" message, then goes into sleep mode? The bios won't show up or anything. (Please note that this is a brand new build, and absolutely NOTHING is installed, and the monitor won't stay on long enough for me to see if I can get the bios up.)
I already went through everything on this list : http://www.tomshardware.com/forum/261145-31-perform-steps-posting-post-boot-video-problems , and everything seemed in check, but nothing got fixed and the "No Signal" sign still shows up.
I know my motherboard is getting power, and I'm not sure what the problem is. I know it's not the monitor itself because it works with my sister's computer.
Here's a list of my specs:
Corsair Air 540 case
ASUS Z87-A Motherboard
GeForce GTX 750 Ti FTW Graphics Card
Intel G3258 4 Pentium Processor
Seagate 2TB BarraCuda SATA
Corsair RMx Series 1000W Power Supply
StarTech 7 Port PCI USB Card Adapter PCIUSB7
NZXT Sentry Mesh Fan Controller
ViewSonic VX2252MH 22" Monitor
Am I possibly missing something that would cause my computer to not run properly? Any and all suggestions would be beneficial! Thank you in advance!
UPDATE: It WAS my motherboard. Thank you for your help!
