Hello everyone. As the title says I am experiencing problems with HDMI to VGA convertors. Anyway ... the convertors I am using are DeTech HDMI ti VGA+YPBPR and a normal HDMI to VGA converter with specs:
Color: Black
Length: Approx. 23.5cm
Power Input: No need extra Power, Power supply from HDMI Power.
It supports full-size high-definition resolution of 720p or 1080p.
Suitable for All HDMI input device (like PC, DVD, PS3, Xbox360, etc ) and VGA output device (like monitor, projectors, etc).
Specifications:
Product Type: HDMI Male to VGA RGB Female Converter adapter.
HDMI input: the HDMI input interface.
VGA output: VGA signal output interface.
Okay ... so the DeTech convertor is brand new ... and it used to work before I changed my motherboard ... but now it does not. While the normal hdmi to vga converter without any power supply cables works ... but only to a small resolution ... if I change the resilution to more than 1024x800 it does not work ... soo .. that's about everything I can say ... ohh and I am using amd rx 480 .... maybe that is important ... and my monitor is lg flatron e2211 ... if anyone knows a way to fix it ... pls share .. thnx in advance.
Color: Black
Specifications:
