Making a guest/travel PC, wanna know what parts I could replace on my main PC and put into my Guest/travel one.
Nicholas_50
Commendable
Oct 8, 2016
19
I have a newish PC that runs great. I need to build another PC and still have perfectly good parts in my main home PC. I dont know what to upgrade in my PC. I was thinking eabout the i7-770k and the Intel SSD thats bigger, but not sure if the upgrades would be worth it, The parts that would be getting replaced are for a guest/travel computer, everything that I would buy would go in my PC. Dont really have a budget in mind but cant upgrade to stuff like a titan or anything.
My current build is;
CPU: intel i7-6700k
CPU Fan: Corsair H100i V2
GPU: Asus GTX 1070 Dual OC 8gb
Motherboard: Gigabyte GA-Z170x-Ultra gaming ATX mobo
Ram: Corsair vengence LPX 16gb 2x8 DDR4-300 Memory
SSD: Samsung 850 250gb 2.5" SSD
HDD: Western Digital 1tb HDD
PSU: Corsair Pro. 650W 80+ Semi-Modular ATX PSU
Case: Corsair 750D ATX Full Tower Case
Also here is a pcpartpicker to my build: https://pcpartpicker.com/list/LcH2Z8
Aeacus
Ambassador
Your planned CPU upgrade is not worth it. You only gain about 9% performance,
comparison: http://cpu.userbenchmark.com/Compare/Intel-Core-i7-6700K-vs-Intel-Core-i7-7700K/3502vs3647
Also, when going for Kaby Lake CPU on Z170 chipset MoBo, you might need to update the BIOS to get support for Kaby Lake CPUs.
I don't suggest going for i7-7700K.
What you can go for is bigger (and faster) SSD and bigger HDD as well.
Like these two drives.
Storage: Samsung 960 PRO 512GB M.2-2280 Solid State Drive ($327.99 @ B&H)
Storage: Hitachi Deskstar NAS 4TB 3.5" 7200RPM Internal Hard Drive ($149.99 @ Adorama)
Total: $477.98
Generated by PCPartPicker 2017-02-15 21:42 EST-0500
Samsung SSD is a M.2 NVMe SSD that is 6 to 10 times faster than regular 2.5" SSD and it mounts to the M.2 SSD slot on your MoBo (located between CPU socket and 1st PCI-E x16 slot).
Further reading: http://www.tomshardware.com/reviews/best-ssds,3891.html
HGST (Hitachi) HDDs are the most reliable ones out there and 4TB of storage space should be more than enough for you.
Further reading: https://www.backblaze.com/blog/hard-drive-reliability-stats-q1-2016/
If you don't want to go with M.2 NVMe SSD then you can go for regular 2.5" SSD too, here i suggest Samsung 850 EVO (500GB),
pcpp: http://pcpartpicker.com/product/FrH48d/samsung-internal-hard-drive-mz75e500bam
Further reading: http://www.tomshardware.com/reviews/best-ssds,3891-2.html
And here's the comparison between Samsung 850 EVO (2.5") and Samsung 960 PRO (M.2 NVMe) drives,
link: http://ssd.userbenchmark.com/Compare/Samsung-850-Evo-500GB-vs-Samsung-960-Pro-NVMe-PCIe-M2-512GB/3477vsm182182
Nicholas_50
Commendable
Oct 8, 2016
19
I was thinking about the Intel SSD 600p Series (512GB, M.2 2280 80mm NVMe PCIe 3.0 x4, 3D1, TLC) Reseller Single Pack for the SSD. is the 960 pro faster or better for the price then the intel ssd? also HDD not looking for an upgrade really, i put prety much everything on my SSD except videos and pictures. Thanks for the quick reply!
Aeacus
Ambassador
The Intel 600p series M.2 SSD is basically a big joke when it comes to the M.2 SSDs.
2 comparisons, 1st Intel 600p vs Samsung 960 Pro,
link: http://ssd.userbenchmark.com/Compare/Intel-600p-Series-NVMe-PCIe-M2-512GB-vs-Samsung-960-Pro-NVMe-PCIe-M2-512GB/m168978vsm182182
and Intel 600p vs Samsung 850 Evo,
link: http://ssd.userbenchmark.com/Compare/Intel-600p-Series-NVMe-PCIe-M2-512GB-vs-Samsung-850-Evo-500GB/m168978vs3477
To put it short, Intel 600p M.2 SSD benefits are that it doesn't take up the 2.5" drive bay and it doesn't need SATA power and data cable to operate.
Nicholas_50
Commendable
Oct 8, 2016
19
Damn, did not know that, thanks for the info! i thought they were way faster or something, but i got wat too much space in my giant ass towere i think ill prob get the 960 SSD, Thanks a ton for the help there my man :).
Nicholas_50
Commendable
Oct 8, 2016
19
I more looking for a replacment to my videocard or an part in my computer and put in my other desktop im planning on builduingnot really and addition to the computer. Thank you for the suggestion though!
Nicholas_50
Commendable
Oct 8, 2016
19
Do you have any other parts i should replace? this is gonna be a guest PC and or a Work/travel PC I can play games on smoothly at 144hz. Or suggestions on what i should get? I Believe I have a CPU at my Office thats an i5-6600k but not Mobo or anything for it.
Ty for the help again, im not sure what to get for this PC, i put mine together slowly overtime from an old prebuilt I got, never made my own fresh PC from scratch.
Aeacus
Ambassador
You can replace your GTX 1070 for GTX 1080 if you like to have better performance on your main PC.
Further reading: http://www.tomshardware.com/reviews/best-gpus,4380.html
Though, GTX 1070 is a great GPU to have and i'd go for Samsung 960 Pro.
Edit:
As far as your 2nd PC goes (with i5-6600K), you can look towards my Skylake build to get an idea how high-end PC with i5-6600K looks like. Full specs in my sig.
Few pics too,
link 1: http://www.tomshardware.co.uk/forum/id-3272328/show-newest-system-upgrade-components.html#19158458
link 2: http://www.tomshardware.co.uk/forum/id-3272328/show-newest-system-upgrade-components/page-2.html#19277195
Nicholas_50
Commendable
Oct 8, 2016
19
You are awesome my man. Last question, You have a case recommendation by chance? like mid tower, no side window and nothing fancy just one that can hold everything and stay cool , Im 100% willing to pay an extra 50$ for one that is strong, and well built like my case the 750D. you know of any?
