Hi everyone! Today I have quite a few parts from several liquid cooling systems I've had in the past and I am looking to sell them. I am based in Minnesota and will only ship to lower 48 states. All prices and images will be displayed next to information about the item. I have an assortment of parts including several radiators, a reservoir, and a GTX 580 HC2. All radiators have been flushed. You may want to flush yourselves if you decide to purchase. Shipping can be discussed via pm based on what you are interested in. All prices are negotiable
Alphacool UT60 360mm Radiator - 70$
- 60mm thick, make sure you have room
- Used lightly for about 1 year
- Includes all original copper plugs
- Can easily handle a CPU/GPU/GPU setup with the right fans
XSPC 120mm Radiator - 20$
- Slim 120mm Rad
Swiftech 240mm Radiator with attached Reservoir and Pump - 50$
- Great option for small liquid cooling setups or beginners in custom liquid cooling
- Used for about 2 years
- Pump has been confirmed working
- Has attached molex and PWM connector for pump power and speed
Swiftech Reservoir - 15$
- Small reservoir that has 4 port options
- Includes mounting hardware
- includes 2 stop fittings as well as a silver kill coil for use in your loop
EVGA GTX 580 Hydro Copper 2 3Gb - 65$
- EVGA card with original Swiftech waterblock installed
- 3Gb of memory
- Never overclocked
- Includes all original pieces and box
- Slim 120mm Rad
- 3Gb of memory
- Never overclocked
