I walked into my local thrift store and i saw a 27in LG monitor there. I thought it prob doesn't work or even come on but i plugged it in to a test strip they have and it powered on fine and even showed the no signal screen cause of course i was not able to plug it into a computer there. So i thought ok its a gamble at this point and picked it for 15 dollars.
When i tested it out on my PC it would come on for what seems like half a second showing my desktop and then go black for 10 secs and again flash my desktop for half a second and repeats. So i thought its a bad capacitor that might need replacing. Checked them and they all looked fine. Tested the AC cord it came with to the multi meter and tested fine read the correct voltage. Order a replacement board instead of trying to solve if it was a bad capacitor (the ones on the board seem little out my league to replace). And even the replacement board does that same thing. So im stuck in thinking maybe the LED strip inside the monitor is bad??? I have a VGA tester i bought to test out monitors and such and it can cycle threw some settings to display colors and lines so when i get to setting that are darker in color and not so bright it doesn't not blink it will stay solid. So its is possible for the LED strip in the monitor to go bad to where if given to much power it will flash very fast and go off for a bit and repeat?
