Hello,
Nice to be a part of this community, been checking topics here everytime.
I've been searching a little about input lag cause I want to buy a TV for gaming and movies... (FPS games, MMOs and Mobas).
The one question I m confused right now, is...
Does input lag limits your max real FPS?
I mean, if I buy a TV with 20ms input lag, will I be limitting my FPS to 50 fps?
(20ms = 1000ms/20ms = 50fps)
Cause, I dont know if input lag works that way, one frame after another is done, syncronized, meaning the next frame will only be processed after the previous is complete...
Or if it works in an "asyncronous" way... the next frame is already being processed while the previous frame is almost done to be shown... using like a cache for the queue idk...
And even further, assuming that the input lag limits my fps, whats the point to buy higher refresh rates monitors? I mean...
20ms = 50 fps = 50 Hz.
16,6ms = 60fps = 60 Hz.
11ms = 90fps = 90 Hz.
8,3ms = 120fps = 120 Hz.
6,9ms = 144fps = 144 Hz.
Cause I looked over some comparison between the input lag gaming monitors and tv... and the gaming monitor with the lowest input I could find was 9ms with 75Hz/60Hz, and 10ms for 144Hz... which would not make sense.
Thank you guys so much.
