+1 for mymutter's suggestion. Not a good idea (assuming the problem has been fixed, definite no if it hasn't). Seems it would be difficult to tell if the problem was fixed with sludge in the coolant, trying to determine old leftovers vs continuing problem. Sometimes a couple of flushes take care of it, other times it can be a real bear. I've seen cars that there was still sludge after 6 or 7 flushes using a flush machine at the shop.
Best case scenario assuming the fix actually fixed the issue and you're just dealing with residual mess in the cooling system it can potentially clog up the radiator by continuing to drive it. That may in turn cause an overheating situation and more problems. Dexcool is junk and more problems than it's worth. You're better off with plain old green.
