Thoughts on parts for 3D animation/Gaming PC about $1200 (white build)
Tyler_134
CPU: Intel Core i5 7400 Quad Core LGA 1151 3.0 GHz CPU Processor
Video Card: ASUS GeForce GTX 1050 Ti DUAL 4GB Video Card
Storage: SanDisk SSD Plus 120GB 2.5" SATA III SSD SDSSDA-120G
WD WD10EZEX 1TB Blue 3.5” 7200RPM SATA3 Hard Drive
Power Supply: Thermaltake TR2 S TRS-450AH2NK 450W 80PLUS ATX Power Supply
Motherboard: ASRock Z270-Extreme4 LGA 1151 ATX Motherboard
RAM: Kingston HyperX FURY 16GB (2x 8GB) DDR3 1600MHz Memory White
Case: DeepCool Dukase V2 Windowed Mid-Tower Case - White
Just wanted some thoughts on the parts I have picked out for my first ever PC build. Aimed for $1000 but dont mind that i went a little over, and also want to keep the white theme. May do a little gaming, Also hoping to upgrade some parts in the future. Buying the parts from www.mwave.com.au, Have limited parts due to being in australia. -_-
Thank you in advance.
CRO5513Y
Expert
Ambassador
Few changes i would make (and some issues that should be addressed):
CPU > Look into Ryzen, they offer great Gaming performance against the i5's and typically superior rendering capabilities.
GPU > I'd try squeeze a RX 470/570 within the price if you can find one they offer 50%+ more Performance.
PSU > Low quality, do you have the Corsair CXM 450 or what other selections are available around the price?
MOBO > No need for a Z board on a locked CPU, these boards are for Overclocking and have no value to your system, swap to a B250 for cheaper.
RAM > Your Motherboard/CPU use DDR4 not DDR3 RAM, you need to change this.
Hope this helps :)
Rexper
Respectable
BANNED
Apr 12, 2017
2,132
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor ($299.00 @ Mwave Australia)
Motherboard: ASRock - AB350 Pro4 ATX AM4 Motherboard ($129.00 @ Mwave Australia)
Memory: G.Skill - FORTIS 16GB (2 x 8GB) DDR4-2400 Memory ($166.98 @ Mwave Australia)
Storage: ADATA - Ultimate SU800 128GB 2.5" Solid State Drive ($84.98 @ Mwave Australia)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($67.99 @ Mwave Australia)
Video Card: Gigabyte - Radeon RX 570 4GB Gaming 4G Video Card ($299.00 @ Mwave Australia)
Case: Deepcool - KENDOMEN Red ATX Mid Tower Case ($65.00 @ Mwave Australia)
Power Supply: Fractal Design - Edison M 450W 80+ Gold Certified Semi-Modular ATX Power Supply ($95.00 @ Mwave Australia)
Total: $1206.95
Generated by PCPartPicker 2017-05-06 16:57 AEST+1000
I just used PCPP for pricing. Basically following CRO5513Y's edits, and changed PSU to high quality.
would suggest u to get a high speed ram like 3000 mhz and up ur ssd to 240gb. 120gb gets filled up fast.
what abt gpu? u already got a cooler?
other parts looks good.
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor ($299.00 @ Centre Com)
Motherboard: MSI - B350M GAMING PRO Micro ATX AM4 Motherboard ($119.00 @ Shopping Express)
Memory: G.Skill - FORTIS 16GB (2 x 8GB) DDR4-2400 Memory ($159.00 @ Umart)
Storage: Crucial - MX300 275GB 2.5" Solid State Drive ($129.00 @ Centre Com)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($64.00 @ Shopping Express)
Video Card: MSI - Radeon RX 480 4GB GAMING X Video Card ($287.00 @ Umart)
Case: Cooler Master - MasterBox 5 (White) ATX Mid Tower Case ($95.00 @ PCCaseGear)
Power Supply: Fractal Design - Edison M 450W 80+ Gold Certified Semi-Modular ATX Power Supply ($89.10 @ Skycomp Technology)
Total: $1241.10
Generated by PCPartPicker 2017-05-06 20:47 AEST+1000
get the dukase if its availale, probably cheaper than my choice of case here.
would suggest a 1x8gb of high speed 3000/3200 ram now and then upgrade to 16 gigs later if budget is tight.
would suggest the ripjaw v 3200 ram for that.
